Hi All i,m going to be changeing my isp soon ,but want to know if i have to cancel my direct debit ,or will the old isp do this ? if i do have to cancel it how do i do this if i can,t log into my old isp details after i migrate ?
For God's sake, don't mention the word cancel to your old ISP. They'd most likely put a cease order on the line - which would override the migration, leave you without internet for nearly 2 weeks & cost you £40+ in new activation fees.BlackDragon said:If you've cancelled your subscription with your old ISP then they shouldn't charge you again. Give them a ring just to be sure
Hi thanks a lot ,so has anyone had any dealings with Nildram and did they cancel the DD ok ?LoadsaMoney said:Be carefull as some ISP's will carry on charging you even though you have migrated away, so when you have migrated, go into your bank and cancel the DD yourself to be safe, took me about 3 months to stop Tiscali billing me even though id migrated away, i got the money back though in the end, but try and save yourself the hastle of having to keep phoning them up to stop them from billing you as your not on their service anymore.![]()
I migrated from them to UKFSN back in October/November time. All went fine - Nildram charged around £7 to cover the 30 day notice period (around a week's worth)jamjar said:Hi thanks a lot ,so has anyone had any dealings with Nildram and did they cancel the DD ok ?![]()
sounds good ,so the Nildram Direct Debit was cancelled by them ok ? also is UKFSN a better isp in your view ,worth the move ?csmager said:I migrated from them to UKFSN back in October/November time. All went fine - Nildram charged around £7 to cover the 30 day notice period (around a week's worth)
Cancelled fine. UKFSN speeds have been fantastic - only quibble I have with Enta is that they will bill you for exceeding your peak usage without warning you are approaching the limit. So you have to keep monitoring usage yourself on http://billing.enta.net/jamjar said:sounds good ,so the Nildram Direct Debit was cancelled by them ok ? also is UKFSN a better isp in your view ,worth the move ?![]()
