- 28 Aug 2013
Hey guys, following the advice given to me on here, i OC'd my i7 920 to 4ghz.
It is stable with IBT through 20 passes, memory passes memtest86, yet to do an 8 hour P95 though.
It has been running fine, it is water cooled so the max temp under a 20pass IBT was 71 on the highest core.
The issue that is puzzling me, is that after being left off for a while, my bios says Oc failure. I go into my bios, change nothing at all and it boots ok after... What could the problem be?
I am using an asus p6t.
Thanks
Thanks
