- 20 Sep 2015
Hello,
I'm having an issue with my PC build about 1 - 1.5 years after it was built. I use the machine primarily for syncing files from another computer (for a backup) and occasional gaming. So the computer is always on but only occasionally used and viewed on a monitor.
The problem has happened twice now, where I go to use the computer and I can't get any signal to the monitor. The steps I try to fix the issue are:
1. Restart
2. Clear cmos
3. Reseat RAM
4. Reseat GPU
5. Turn computer off, unplug and leave for half an hour
I have got it working again, but to be honest I'm not sure which of these steps worked or why it's happening. The computer sounds like it starts normally and the monitor seems to detect there is a signal (automatically turns on) but then comes up with a 'No Signal Found' message.
The specs are :
Intel Core i5-6600
Gigabyte GA-Z170N-WIFI Intel Z170
Samsung 250GB 850 EVO
Kingston Fury Black 16GB (2x8GB) DDR4
Silverstone SFX-L 500W '80 Plus Gold'
Silverstone SST-RVZ01 Raven Mini-ITX
Gigabyte GeForce GTX 970 "Mini-ITX"
Any advice would be greatly appreciated.
Thanks
Andrew
1. Restart
2. Clear cmos
3. Reseat RAM
4. Reseat GPU
The specs are :
Intel Core i5-6600
Thanks
Andrew
