Hello Watercooling forum,
I recently got my hands on this cooler from OverclockersUK.
I have had this installed on a Gigabyte G97X Gaming 3 motherboard, for an Intel i7-4790K (~4GHz) CPU. It is set to boot to a Samsung 860 EVO 250 GB SSD with Windows 10 Professional installed as the operating system on that drive.
The fans for the radiator and the component placed over the CPU work fine (having plugged the appropriate cables into the sys_fan and cpu_opt headers, respectively). But the pump system for this AIO watercooler is not consistently operating.
It has come on for between 30 seconds and 1 minute (with the cooling effect being noticeable), but has not stayed on for much longer when going into BIOS. It has also not come on either when the drive has booted to Windows, or when logging in.
I have made sure the backplate is fasted securely to the motherboard and that the component placed over the CPU, is fasted securely with the 4 screws provided, over the CPU chip that has a fairly even layer of thermal paste applied to it.
If I am able to login to Windows, using Speccy to check the temperature of the components. I can see that the temperature of the other components is quite low (~30 degrees Celsius or less, as expected), but the CPU temperature is at least 95 degrees Celsius, on a consistent basis when starting up.
Would anyone have any idea of what the problem is? I can provide more information as required.
Thanks in advance for your help Watercooling forum
![Smile :) :)](/styles/default/xenforo/vbSmilies/Normal/smile.gif)
