Yes, as shown in the video.I know it sounds stupid... But you did remove any plastic film off the bottom of the CPU coldplate prior to fitting?
Two* 4 pin connectors is what I meant*, should there also be a power cable?
Right, so if only 1 connector is to be connected to a motherboard header, where would the other connector be placed? (There is one 4 pin connector from the Fan/Radiator combo and one 4 pin connector coming from the CPU fan that is placed on top of the CPU chip).The connector from the fan connects to the pump block and the other 4 pin connector connects to the motherboard
( thats how i understand from the video and comments )
Ah...how come one is able to detach the connector on the radiator from itself and attach it to the motherboard? If one is to leave it attached to itself for it to work, that is annoying.*
After tying to have the radiator connected to itself (as it was when I first unpacked it) and 'The cable pictured above goes to the cpu_fan header and thats it.'. This, once again, caused the pump to come on for a few seconds, deactivate itself afterwards and then not come on again for that boot attempt, or any future boot attempts (even after getting to the Windows login screen and logging in).
I am not sure what else to try, I have the 4 pin connector coming from the radiator connected to the other connector that's part of the radiator/fan combination, but still nothing.*
