- 17 Apr 2026
- Hampshire
Anyone had issues with this case. Just completed a build and boom sparks and smoke...couldn't believe it
Yeah hadn't changed anything or added any funky RGB etc. It was as also a dead simple build so not sure where a short would come in. Given the sparks and smoke came from the same area of the buttons and usbs id be suprised if the issue with was the build inside the case tbhI've not had any issues with either of the Kolink cases I've used (Citadel Mesh and Void X)
There's very little case related that could cause sparks or smoke - the only thing I can think of would be mixing up some of the RGB connections especially if adding additional items or connecting to a different rgb controller e.g. motherboard.
can you post a pic of the pcb?Given the sparks and smoke came from the same area of the buttons and usbs id be suprised if the issue with was the build inside the case tbh
