- 31 Oct 2006
- Uttoxeter
So I decided to replace the stock fans on the Aorus 360mm AIO with the new Corsair QL fans to keep all the fans in my system the same however I have a issue with it right now.
So on the stock fans the ARGB connector is a small 3 pin one like in the picture below
and the connector for them coming from the pump is obv small also like in the picture below (its the connector cable thats on its own in the picture top left):
Now the ARGB connector on the Corsair QL fans is a bigger 4 pin connector so this obviously wont plug into the connectors coming from the pump. Is there anything I can do here or do I just have to put the stock fans back on so that they can be connected up properly and RIP £100 on the 3x QL fans
