- 30 Oct 2014
- Norfolk
I decided to move from an ATX to ITX as I changed my desk to a much smaller one and needed a smaller case.
I turn it on, the PSU fan spins for a second, the RAM RGB lights up, the AIO cooler fans and additional case fan both spin.
I try connecting to my monitor with a HDMI and then try with a display port, directly into a motherboard, I do not have a graphics card at the moment, there is no display on the screen.
I got a notification on my phone that my desktop has joined my mesh network, so supposedly it has booted to the home screen ( I had no password to get into the desktop )
To note - The motherboard and PSU is used from Ebay, and from high rated sellers, there aren't any beeps on the motherboard to indicate theres any sort of issue.
The 3-pin CPU cable from the cooler is plugged into the 4 pin header labeled CPU fan, which should be fine.
Specs:
Motherboard is AMD B550 Mini-ITX AORUS
ICUE H100i elite Capellix AIO
iAMD RYZEN 9 3900X
Specs:
iAMD RYZEN 9 3900X
