Hey everyone, I recently purchased a new PC components to build a PC the following links are the components which I selected.
Mobo: http://www.overclockers.co.uk/showproduct.php?prodid=MB-070-AK&groupid=701&catid=1903&subcat=2046
RAM: http://www.overclockers.co.uk/showproduct.php?prodid=MY-076-PA&groupid=701&catid=8&subcat=1387
CPU: http://www.overclockers.co.uk/showproduct.php?prodid=CP-336-AM&groupid=701&catid=1967&subcat=1825
As you can see I have selected 2100MHz RAM and the mobo supports up to 2100MHz, when I go into the BIOS settings the RAM is set to default 1600MHz when I try to increase the speed of the RAM the computer doesnt boot up.
I have to reset computer and when I go and check the RAM speed the default speed has been changed to 866MHz, and when it boots up I sometimes get a blue screen of death saying "not less or equal".
Is there any way I can get my RAM speed upto 2100MHz?
I am currently running Windows 7 32bit (but have a patched kernel which allows me to have more than 4Gb)
Any help to resolve this matter would be gladly appreciated.
Lhexh.
Lhexh.
