it clocks! it clocks!!! but what should my temps be...
Tryed 270 but it wouldnt boot :( the BIOS even reset because it couldnt boot.
What PRIME95 test should I run to test stability?
Cheers
MC_Bob
mc_bob said:
Is there a performance decrease when you change the multiplyer down to 4x or 3x. Im on 3x now and Ive got my 3200+ at 2.6Ghz (2.0) stock.
MC_Bob
No change. I was running mine at 279 x5 (I forgot to change it) and got same superpi times as when I dropped it down to 3 - also had to do a bit of digging to find it in the Bios :S
Ok cool, wonder what the actual purpose of it is.
Does anyone know how I can test the stability of it and max temps?
Torture test on SuperPi got it up to 40c after 1hour on stock cooler :D, Im still going to have to replace that, and the fan is on reduced rpm.
MC_Bob
