Hi guys back again!
I've been in here before regarding my antec aria / xp2000 system. Basically, the old girl is running 57 C idle, up to 65 load.
Got a silent (but usual rpm) akasa hs+f, 1x akasa amber 80mm and 1 x 60mm Silenx fans all at full 12 v goodness.
So basically she's running HOT! And there's not much more I can do because I want it lovely and quiet, and as the case is tiny temps will be high, but not this high. The only other fan I could replace is the 120mm jobee in the psu - its quite loud and honestly it barely pushes any air at all!
So on my old board (k7s5a) I could bring the cpu FSB from the 133 down to 100 to give me a clock speed of 1215mhz. Given that I'm not gaming these days, this is now a viable option. Will it reduce heat much?
Also 1 problem - the bios doesnt allow fsb changing. Its an Asus k7S8x-mx micro atx board. I was going to try doing it through Clockgen, but the board isnt supported.
What are my options for underclocking? Or is it not worth it in terms of reduced heat?
