The CPU Cooler clearance seems very limiting for a case designed for air cooling... Can you confirm it fits things like the NH-D15 please?
I've got the P400S which AFAIK is the same case bar the mesh front and it fits a D15S in no problem.
No it won't. And sadly as an owner of a u14-s it won't fit that either and I don't want to change cooler and case. It's a shame as the more compact meshify C fits these coolers. Seems like a bit of an oversight to not just have that extra 1cm of clearanceThe CPU Cooler clearance seems very limiting for a case designed for air cooling... Can you confirm it fits things like the NH-D15 please?
that would be good to know as I fancy getting the beast NH-D15 and the case seems good.The CPU Cooler clearance seems very limiting for a case designed for air cooling... Can you confirm it fits things like the NH-D15 please?
thanks for confirming that the top of the D15 does not stop the glass panel from being attached (unlike by sapphire dual vapour cooler and my Kalman side-less case)
what have you got on top of your D15S?
Thanks for confirming that. It looks like the NH-D15 heatsink is 160mm tall and 165mm with fans. Those are low profile RAM right?
RAM is the 8PACK 3200 stuff so taller than normal memory. The heatsink in the pic is the D15S which has a large cutout on the front to give clearance over the RAM and only one fan (centre).
The extra height on the D15 is purely from the fan sitting high as it hangs over the RAM slots. The middle fan you can mount lower. There's only a couple of degrees difference between using dual fan and single fan setups.
the case says 160mm max cooler height. The NH-D15 is 165mm high.No it won't. And sadly as an owner of a u14-s it won't fit that either and I don't want to change cooler and case. It's a shame as the more compact meshify C fits these coolers. Seems like a bit of an oversight to not just have that extra 1cm of clearance
