** IT'S TOO BLOODY HOT - 10% DISCOUNT INSIDE **
  • Thread starter Thread starter rjk
  • Start date Start date
rjk
rjk
Caporegime
8 Aug 2007
Hello OcUKers
After spending yesterday melting in the office, and deciding that shorts and a vest are suitable work attire this morning, I have decided to turn my misery into an advantage for you guys.
If you are looking to purchase any Fan or Heatsink product from Overclockers UK, then today [and tomorrow] is your lucky day.
From now until Friday night, we are running a 10% discount code for qualifying products for customers using the code - COOLDOWN10 at checkout.
This is a great opportunity to upgrade to a nice AIO cooler or buy a bunch of fans to cool down your system.
This discount also includes the Raijintek Triton cooler which has been flying off the shelves in our warehouse!
Go Wild!
what product you trying to make it work on?
Raijintek EreBoss High Performance CPU Cooler, NZXT FN-120 Enthusiast Performance Case Fan - 120mm and EK Water Blocks EK-Cable Y-Splitter 2-Fan PWM. I'm entering it in the "VOUCHER" text box and getting "This voucher () does not exist, please check and try again - please call OcUK if you are having problems."
ignore please delete. Was heat, and my slowness, stupidness etc etc. I thought I could use the 10% on a hard drive. . . . .
Tempted to change all my case fans for those black/brown noctuas. I've got a mix of about 3/4 different fans from old cases and builds. Plus my XL R2 front fans are quite noisy.
Another thing, are the black and brown Noctua fans threaded in the screw holes? I had the corsair AF/SP ones before and getting a screw to make it marks was near impossible so I gave up..
now is the best time.
no fans come pre threaded in the screw holes that I am aware of, most fans come with self tappers to install or noise dampening grommets and self tappers in the case of noctua.
Would the grommets alone be enough to hold the fan, or 1 screw in each corner? I seem to have terrible trouble with the rubber grommet cornered fans, plastic is easy though.
I've got 5 noctua case fans installed using just the grommets, none have fallen off in the 3 years they have been installed :)
