iTunes Problem
23 Nov 2004
Sometime ago i spent ages putting all of my music CD's onto my PC.
I have been able to add all of my Albums to iTunes all but a few. A couple of albums won't go in there. I have tried the following:
1) File > Add Folder to library
2) File > Add Files to library
3) Selecting files in explorer and drag 'n' drop into the iTunes library.
iTunes doesn't seem to do anything to put them in there and they don't display in the listing. This is really annoying as it is two albums i got recently (Razorlight and Paolo Nutini which i really want on my iPod.
Any advice? Or should i re-install iTunes, etc?
Cheers
Matt
What format are they in? If you arn't bothered about your library you could delete or rename your My Music\iTunes\iTunes Library.itl file and see what happens
