ITX build, my first SFF!
19 Sep 2010
The North
Hi all
I've decided that I wanted a small form factor PC for lounge gaming and media, rather than going the console route, so time to get my build on! :p
I opted for the Raven case after a lot of research, and it seems that despite being a very compact case, it is still incredibly capable.
Now, in terms of budget, I was originally looking at ~£500, which I did go slightly over, but for the spec I ended up with will be well worth it, I think! Second hand parts helped a lot at lowering the total cost, so the below price isn't totally accurate!
So, the spec is nice and simple:
YOUR BASKET
1 x Powercolor Radeon R9 280X TurboDUO 3072MB GDDR5 PCI-Express Graphics Card £229.99
1 x Intel Core i3-4150 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £89.99
1 x Silverstone Strider SFX Gold 450w '80 Plus Gold' Modular Power Supply (SST-ST45SF-G) £76.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Kit £71.99
1 x Silverstone SST-RVZ01 Raven Mini-ITX - Black £69.98
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £67.99
1 x Asus H81I-Plus Intel H81 (Socket 1150) DDR3 Mini ITX Motherboard £58.99
1 x Western Digital Scorpio Blue 2.5" 750GB 5400RPM SATA 6Gb/s 8MB Cache - OEM (WD7500BPVX) HDD £41.99
Total : £717.52 (includes shipping : £8.00).
This isn't the exact motherboard as it was purchased elsewhere, but similar enough to give you guys a spec idea.
To be honest, I'm looking forward to giving the case a go. It should be very different to the mid/full tower builds I've done before!
Second hand parts that arrived nice and early today, the bulk however...
:D
Should be nice little build especially with aid of mantle I gotta find pics of my last itx build wc coolermsster 130 custom loop was a tight squeeze keep meaning make a thread
GPU bracket out
And there it is
PSU cage out
SFX PSU's are smaller than I thought!
Fully modular, which is a bonus
PSU mounted into its cage
Modular cables attached and PSU cage installed
CPU and mobo
Nothing fancy, but it'll do me nicely
Mobo installed, with the stock Intel cooler and the RAM installed too. I was considering an aftermarket cooler, but I'll see how the stock one handles it first
Cable management is starting to look difficult!
GPU mounted into the bracket
GPU installed
Hard drives installed, and cables are a pain to try and arrange!
And the final for now
