ITX Case Advice!
@Jackabamba
Just a heads-up to say that the Ncase M1 pre-order are supposed to reopen today (though they aren't the most organised bunch. There's every chance the date will suddenly change).
Got my Cougar QBX on Saturday.
My main complaint is that cable management is quite limited.
The space behind the motherboard is a bit too narrow for the ATX power cable, and as far as I can tell it's not possible to tie up cables so they stay in place and don't block the PSU grille.
There is a cable routing hole at the rear of the motherboard, but the PSU limits its usability unless you put uncomfortably tight bends in cables.
If you're a neat freak with your cable management, then look elsewhere - if you can take an out of sight, out of mind approach then it's a really good case for the money
