- 8 Feb 2008
- UK
Hi guys,
Would like your input on a small form factor build for office use. I'm used to more gaming oriented builds so could use some pointers as to what gives the best bang per buck at this level. I'm looking for:
Case (as small as I can possibly get whilst ideally retaining 3.5" support for a drive I'd like to bring across - OCUK has 178 ITX cases which makes it kind of a daunting task but if we discard the larger mini-gaming/LAN-rig focussed cases it might help narrow the choices down)
PSU (was looking at the smaller bequiet 300W SFX and TFX units)
CPU (with integrated graphics, want to avoid a discrete card to keep overall size down to absolute minimum)
Motherboard
RAM
All in at the £500 mark would be nice.
Cheers for the help.
Motherboard
RAM
