tbh VIA have a good linux following, I'd assume that anything on there that works under windows will work under linux.
If you just need it for HTPC then I'd have thought you'ed be ok without a PCI/-E slot?
could go external CD/DVD but I get the point with that.
also, it's ugly but is gonna be behind your screen. when will you see it?
Right thanks for all the help guys i have spec'd a system up from all the suggestions. Just a few more things with the Antec case will a standard CPU cooler fit in there ok? Also will the CPU i've picked handle HD playback ok?
OK so the stuff i picked was
Intel Celeron 430 1.80GHz Socket 775 FSB800 £32.86
Antec ISK 310 - 150 Mini ITX Case - With 150W PSU £66.30
ZOTAC GeForce 9300-ITX WiFi Socket 775 DDR2 £104.45
2GB DDR2 667MHz Value Memory Non ECC Unbuffered £36.99
Western Digital WD1600BEVT 160GB 2.5" Hard Drive £32.71
LG GT20N 8x Slim Notebook DVD±RW £22.99
Total is somewhere around £300 can anyone see anywhere i can improve with no added costs ?
I would strongly suggest going for an Atom 330 ION instead. They really are designed for HTPC's
The only problem is that they are DDR3, so the memory is slightly more expensive
and give plenty of perforance for HD playback.
They also use less power, and are silent, passivly cooled, if those are important too you, and maybe in the future u could replace the hdd with a ssd, making it a totally silent system
also, the current ones work out cheaper that ur mobo/cpu combo.
at £110, u get pretty much the whole system, and no need to worry about cpu cooler either
most of the ION 330 boards I've seen are DDR2, I have the asus one, built in bluetooth and comes with xp mce. bit picky on ram and a whiny 40mm fan but that's not too bad...ocuk do stock them..
http://www.overclockers.co.uk/showproduct.php?prodid=MB-364-AS&groupid=701&catid=5&subcat=1436
Mine does now Adam, but only because my case has an 80mm fan blowing down over the heatsink. I just removed the header cable rather than the whole fan in case I remove it or sell it on. Without the 80mm fan it got pretty toasty pretty quickly and I reckon it may suffer, but other boards are passive....
ASFAIK all the passive ones are the single core Atom but with good airflow you should be fine.
I prefer the Zotac board with built-in Wifi and a 16x PCI-E slot personally (ION-F-E I think it is). Can be had for £110 if you shop around.
