It depends on the two-factor implementation they've used. Some have a time-limited code, usually 30-60 seconds, that is generated by an app. In theory you could also key-log that app and gather the codes, but you'd only have a very short timeframe to use it. The best MFA is something like Duo, where the user gets a push alert when someone has successfully used their username/password (with timestamp and geo-located IP address) and they have to manually approve the access before authentication is completed. If it's a hacker, the user should know that they haven't tried to log on and reject accordingly.pursuing the question of theoretical ways bank accounts could be breached -
with dual factor authentification, a key logger would be of no use to hack a bank account - since dual factor is authorizing just that one session ?
A doubtful vector. PKI security is a big thing in any organisation and banks especially have very stringent procedures for generating them. No way can a rogue employee just create themselves a sub-domain tied to a new webserver and sign it with the bank's private key without going through loads of process that would pick up nefarious behaviour.a viable hack ? with bank insider (so unlikely), generate an authorized certificate for the site and, via dns diversion, intercept and taken control of the session ? (they are improving certificate integrity)
The current vector that banks are worried about is the SWIFT network for inter-bank transfers, it's been penetrated in a few banks leading to events like the $1billion dollar Bangladesh Central Bank heist. Why bother attacking individual customers when you can penetrate the bank itself?
