- 9 Jun 2011
How good is the j batch on 5820k and average Overclock
When did you all buy your 5820Ks? J batch currently doing the rounds at OcUK? Want to upgrade to X99 but not in a huge hurry but don't mind starting early with just buying the CPU.
I just bought an i7-5820k, I am probably being stupid here but how do you know what batch your CPU is from?
Either IHS or says on the box. On the bottom right of white label.
So I bought mine second hand, all I got was the CPU itself. Would the batch be L537B(8?)473?
.L443C361 here. No idea exactly how long ago it was made. Bought it second hand as part of a bundle. Only tried clocking it briefly with auto voltage, 4.5ghz resulted in 1.312v at load under XTU.
i wouldnt recomend above 4.5ghz with stock cooler
It was made in the 43rd week of 2014. L = Malaysia, 4 = 2014, 43 = the week.
It seems latter cpu are a bit better, especially L522 onward.
