Seem rather complicated, the BMW system much easier with the rubber puck
Which is fine, but unless you know what a "solid part of the subframe" is (which given that I'm NOT sticking my head underneath a car on only a jack for long enough to have a good look around), it's of no help whatsoever to a noob like me.Axle stand -find a solid part the subframe. Maybe with a piece of wood on top. Depends what you lifting the car for i guess
Heres a video from a quick search, no need to create a thread, especially in a non Audi focused forum
Why Manufacturers can't clearly mark and included them in the manual is beyond me.
yes you put on the lower control arm ? I wouldn't do that similar to comments in the threads I'd read
e: bmw e36 I used to jack with the inbuilt sill holes and their wheel jack , and then put the axel stand on the pad inbuilt into the sill
frankly they don't expect people to diy now.
e2: yes I've usually taken off a wheel and that is under the sill too, nearer front,, so that will probably save me.
Helpful ThanksWell if you can’t tell yourself then don’t work on cars would be the obvious answer.
The only jacking points mentioned in the R56 Mini manual (and indeed most recent-ish cars I've owned) are the ones that a supplied jack fits (i.e. the ones you linked a picture of above)Many cars have clear lifting and stand points in the manual for noobs.
Which I'm sure are pretty obvious if you do it day in day out, but as noob looking at a likely rust covered underside of the car, then they aren't "obvious".The subframe bolts are pretty obvious hard points to use as axle stand points.
I don't yet own a trolley jack, but I was aware of that. And already use a large sheet of thick ply when using the "emergency" scissor jack on the couple of occasions I've needed to jack a car up.Goes without saying to ensure the trolley jack wheels can roll ( ply etc) and the car is parked on the flat too.
You absolutely do not put an axle stand on a suspension arm ever!
The chance of it slipping is way too great to risk.
Mods, I’m not trolling jpaul here, but if one can’t figure out how to jack a car up correctly, then that person imo shouldn’t be trying to do anything mechanical on said car.
audi b9 ... yes I realise you never put anything on control arm (I was being sarcastic e:about the video)I’ve a couple here that I can stick on the ramp and show you where to jack it safely.
Because as much as everyone loves to jump on the @jpaul mockery bandwagon, I can kind of see the point in this instance.Don’t understand why you are replying to me like this.
I'm a noob in that I lack experience, not necessarily competence or "skill". No I don't expect it to be for everyone (in the same way Electrical work and Gas work isn't for everyone), but there's no need for elitist "gating" for something as basic as this.You are a self claimed ‘noob’ yet expect working on cars to be for everyone ? There is some inferred self competence if you DIY.
Maybe, maybe not. But honestly would it be so hard to provide a photo with arrows in the owners manual?A Yellow cross would soon be covered in dirt so not sure what value that has
How hard would it be for manufacturers to paint a big yellow cross on the suggested points underneath?
It's not in the manufacturers interest to do this.
They highlight underbonnet maintenance items like the dipstick and squirter reservoir, but this is for the standard regular checks and top ups.
The manufacturers don't want owners putting the car on stands and going underneath.
Why Manufacturers can't clearly mark and include them in the manual is beyond me.
Yes i ended up doing the same thing, skinny hand-crank jack and jack stands right next to each other did the job. Cumbersome but works.
