Troubleshooting ZiPhone
Or:
IT BROKE WHAT DO I DO?!?!??!?!?!?!?!?!
ZiPhone has worked reliably for many iPhone users, but occasionally things do go
wrong. Below are some problems that some users have encountered. Please try to
work through these troubleshooting steps before you come into the IRC channels asking
for help. Please keep in mind that there are far more ZiPhone users than there are
ZiPhone developers. The more users who can help themselves using the information
below, the more time the developers have to add new features and fix the occasional
bug.
I) Other Jailbreaks
The most common source of problems is running ZiPhone after using other 1.1.3
jailbreak solutions. The best case is to run ZiPhone on a cleanly restored 1.1.3
phone. Other configurations that are known to work include starting with a
jailbreakme.com 1.1.1 phone or oktoprep 1.1.2, possibly then updated to 1.1.3
using iTunes.
It you start with a "Nate" or "Official Dev Team" jailbreak of 1.1.3, it's important
that you tell iTunes to treat the phone as a NEW phone. That is, do not restore
your existing phone's settings and configuration to the ZiPhone jailbroken phone.
Restoring settings from other jailbreaks is *known* to cause problems.
If your phone is behaving badly after two different 1.1.3 jailbreaks, your best bet
is to restore to a clean 1.1.3 install with iTunes and then run ZiPhone. Clicking
the Restore button in iTunes should get you started. When prompted about backing up
settings, choose "Do Not Backup". You WILL lose your settings on your phone, but any
contacts or other data synced to your PC will be synced back when your restore is
complete.
II) Errors running ZiPhone
ZiPhone may display an error message and fail to run, or it may hang at the
"waiting for phone" steps. If this happens, you should try the following:
1) Make sure iTunes is shut down.
2) Make sure iTunesHelper and any other services or daemons releated to iTunes
are not running.
3) Try putting your phone into recovery mode manually (see below).
4) Upgrade to iTunes 7.6 and sync your phone with iTunes before trying ZiPhone.
5) Reboot your computer.
6) If possible, try another computer.
To enter recovery mode manually:
1) Quit iTunes and close any "helper" daemons.
2) Hold the power button on your phone until the "slide to power off" message appears.
3) Slide to power off and wait for the screen to go completely black.
4) Unplug your phone from the cable or dock.
5) Hold the HOME button on the phone and reconnect it to the cable or dock.
6) Continue holding HOME while the Apple logo appears.
7) Continue holding HOME until the "Connect to iTunes" graphic appears.
8) Release HOME. You're now in "Recovery" mode (not to be confused with DFU mode).
9) Try running ZiPhone again.
Previous versions of iTunes were known to crash on PPC Macs or on Mac OS X 10.4
(Tiger). As of version 2.3 all known issues are fixed, and ZiPhone should work
on Intel or PPC Macs running 10.4 or 10.5. Please make sure you're using at least
version 2.3 before reporting errors on Tiger or PPC Macs.
III) Problems After Jailbreak
After successfully completing a jailbreak, you may notice some of the
following issues:
* YouTube not available
* No cell access (phone and/or SMS don't work)
Most of these issues can be fixed by running one or both of the Reset Settings
options in the phone's settings application.
1) Tap on Settings from the home screen.
2) Choose General
3) Choose Reset (all the way on the bottom)
4) First try "Reset Network Settings"
The phone will reboot. If things still aren't working, go back and try
"Reset All Settings".
* Visual Voicemail doesn't work (official carriers only)
To fix Visual Voice mail, launch the Phone application and click Voicemail. It
will probably try to call into the voicemail phone number. If it doesn't tap
the button to make it call. Let the call complete and check your voicemail.
End the call, wait a minute or two, then try visual voicemail again. You should
be prompted to enter your voicemaill password and Visual Voicemail will work after
that. Some have had luck by changing their password during the phone call or
rebooting afterwards. Of course, Visual Voicemail ONLY works with official
iPhone carriers, so if you're using an unlocked phone with another SIM, this
won't work no matter what you do.
IV) Starting Over
If none of the above helped, it may be necessary to restore your phone to a
completely clean state before trying again. To do this, perform a
"DFU Restore" as follows:
A) The Easy Way:
1) Shutdown iTunes and connect the phone.
2) Run ziphone -D
3) Your phone will show the "Connect to iTunes" screen.
4) iTunes should be able to restore 1.1.3 firmware to your phone.
Note that this isn't "full" hardware DFU mode, but it should be adequate
to install a current firmware with iTunes.
If you enter this mode by mistake, ziphone -t should reboot normally.
B) Full Hardware DFU (required for downgrades):
Note that using a cable instead of the dock may make it easier to press
buttons in the following steps without losing the connection.
1) Start iTunes and plug the phone in.
2) With the phone powered on, hold both the POWER and HOME buttons for
seven seconds. The screen should turn black.
3) Wait two seconds while the screen is black and release the POWER button
while still holding the HOME button.
4) The screen will remain black, but after a few more seconds iTunes will
detect the phone in recovery mode.
5) Release the HOME button and proceed to restore firmware with iTunes.
Timing is fairly important on this. If your phone reboots or ends up in
recovery mode, just try again. You might want to look at a clock that shows
seconds while you do this. The timing needs to be exact for it to work.
If you enter this mode by mistake, hold the HOME and POWER buttons for
seven seconds until you see the Apple logo and immediately release both
buttons. The phone should reboot normally, assuming a valid firmware image
is present on the phone.
