James’s Epic Build (Log) ft. Singularity Computer Spectre Case
30 Mar 2018
Log Summary
Post 1 - General Summary of My Build Goal and Me Rambling
Post 2 - Complete listing of Parts and Tools (Reviews of parts in process)
Post 3 - Videos
Post 4 - Final Photos (Build not complete)
Hey all. I have been building PCs for about 20 years now. My builds have always been “best bang for your buck” builds with zero thought for looks other then trying to get a cool looking case. Over the summer, I was up for a new machine and decided to go big with a 1080ti and settled on the EVGA SC2 version. I quickly learned that graphics cards run a lot hotter and louder than before and really didn’t like the hover noise that they make when gaming. So, to find a quieter solution, I picked up one of EVGA’s hybrids and fell in love with the cool quiet running of water cooling . . . and I was bit by the water bug. While researching these I was exposed to the amazing custom watercooling culture and I am hooked. I both loved the beautiful machines that I saw as well as the the posts and videos that folks made while building them.
So, I decided to do the same. I want to build a beautiful monster gaming PC and I want to document my process to share with others to give back for all the great builds I got to enjoy seeing built. I will do that through photos (photography is a hobby) and through videos.
Some fun facts. I have never done a water loop before (and going to go with glass tubing), I have never done custom cables before, and I have never documented a process or shoot video before other than an iphone (focusing sucks on my canon 6d from what I can tell). So, I will be sharing my experiences with all of this as well. I hope to use this thread to document all parts, the process, and the results. I hope to add a post every few days as I work through the process. I am a public accountant and on the tail end of my busy season so please forgive my slower posts.
I am actually pretty far along with the getting parts process but I am missing my case, which is quoted at 4 weeks out. The computer is currently up and running as I wanted to ensure everything was stable before adding a water loop to it. Currently dealing with some BSOD with lightroom, ugh. But ideally it needs to be 100% before the waterloop goes on.
pownFDwgj
Still working on the color Combos
pm4V0Etmj
pn3xNiMfj
Only metal fans I could find.
pn2j8y2Fj
pnDtfhNnj
Sucks pretty lights :D
po2DlLVHj
Glad I got these monsters at MSRP
pnUgx617j
I hope every enjoys.
Cheers,
James
Here is a complete listing of parts so far. One of my pet peeves when looking up parts was folks not including what goes into the build. So, I tried to include everything including the kitchen sink.
If you can't find any of these parts here https://www.overclockers.co.uk/, pm and I can give you more details if you want to know exactly the part youre looking for.
Computer Hardware
CPU: Intel Core i7-7820X Processor
Motherboard: Asus Rampage VI Extreme
RAM: G.SKILL TridentZ RGB DDR4 3000MHz 8x8gigs
GPU Waterblock: EKWB, Nickel
GPU: EVGA GeForce GTX 1080 Ti FTW3 HYBRID
HD: Samsung 960 Evo m.2 500GB
PSU: EVGA SuperNOVA 1200 P2
Monitors
Asus PG27UQ - 4k, 144hz, HDR, IPS
Asus PB277 - 2k, 75hz.
Keyboard and Mouse
Logitech 810 Spectrium
Logitech 903
Logitech Powerplay
Water Cooling
CPU Water Block: Heatkiller IV Pro
GPU Cover: EKWB EK-FC1080 GTX Ti Backplate, Nickel
Radiator 1: Alphacool NexXxoS UT60 Full Copper 360mm
Radiator 2: Alphacool NexXxoS UT60 Full Copper X-Flow 360mm
Fans: 3x InWin Polaris RGB Aluminum Twin Pack Fan Kit
Glass Tubing: 3 x Alphacool HardTube 16/11mm Borosilicate Glass - 60cm
Pump: Aquacomputer D5 Pump Motor with PWM Input and Speed Signal.
Fluid: TBD
Fittings, all in Black Sparkling
50 x Bitspower G1/4" to Enhance Multi-Link Fitting for 16mm OD Rigid Tubing
14 x Bitspower 90-Degree With Dual Inner G1/4" Extender
5 x Bitspower G1/4" Male to Female Extender Fitting, 90° Rotary
3 x Bitspower G 1/4" Dual Rotary 90 Degree IG 1/4" Adapter
12 x Bitspower Premium G1/4" Stop Fitting
1 x Bitspower Dual IG1/4" Black Sparkle Triple Rotary Snake-Style Adapter
2 x Bitspower Black Sparkle Dual Rotary Mini Valve With G1/4" Extender
Custom Sleeving
MDPC-X Small XTC Sleeve - Lambo-Greeny, Blackest-Black, Shade-19, and Platinum-Grey
Wire: M1 Custom 2.4mm OD Black and White 16AWG
Cable Combs: OverkillPC's Knuckle Combs - 24pin x 5
OverkillPC's Knuckle Combs - 16pin x 10
OverkillPC's Knuckle Combs - 14pin x 5
Connectors and pins
Female ATX Terminal x200, 24pin ATX Female Connector x 1, 8pin EPS Female Connector x 3, 4pin EPS Female Connector x 1, 18pin Female Connector x 1, 10pin Female Connector x1, 6pin AUX Female Connector x2, 8pin PCI-E Female Connector x8, 4pin Power Female Connector x1, 4pin Power Male Connector x2, Sata Power Crimp Style Connector x1, Sata Power Push-In Style Connector x1, Sata Power Push-In Style End Cap x1
Water Cooling Tools:
Dremel 200-1/15 Two-Speed Rotary Tool Kit
Dremel Wheel
Sandpaper
Glass Cutter
Gloves
Cable Sleeving Tools:
Molex Pin Remover
Heat Gun
MultiMeter
Wire Crimpers
Wire Strippers
Other
Brushed Metal Vynl Wrap
Videos
Inwin Polaris RGB Aluminium Fans
Inwin Polaris RGB Aluminium Fans - 2 -
Primochill Vue Sterling Silver and NV Green - Fluid Decisions -
Bitspower Fittings -
7820x Deliding video -
Cutting 16mm Glass Tube
It will be fascinating to see the build develop in this new case. Looking forward to see it grow.
Thanks.
Post 2 updated with all the parts to date.
Also still working on color combos. I didnt want to go heavy on color and greens my favorite. Was thinking only green accents but also thinking only going color with the fluids so I can switch it up. I dont know. Still deciding. Opinions?
First pic with the green and grey :)
Had never heard of that case manufacturer before but looks very interesting, will definitely be keeping my eye on this one :)
I like the first pic with the grey and green
Thanks. Yea, this is their first case. Singularity computers is a custom pc builder in Australia that has a variety of watercooling components , this is their first time with a case though. What's unusual is that its being produced in the US. So, not sure how much on hands efforts were completed by them.
Why get the hybrid GPU then take the kit off to put a block on it? Seems a waste of buying the hybrid kit just to get rid of it all?
When I bought the cards in December I was just learning about water cooling and custom loops. The hybrid card was only $50 more and I trusted and wanted a cooler/queiter set up and the hybrids made sense. I didn’t trust myself to do a custom loop but running the aoi and reading a lot made me feel more comfortable trying it.
Only a month later did I decide to go a custom loop.
shame just out of step - up program ? if they still do it - just switch to they hydro copper
