Java, fatal exception.
Caporegime
12 Mar 2004
England
Everytime I build my project into a jar file with netbeans and try to run it I get a fatal exception error message and the program exits. Does anyone know what can cause this?
Also when I select "run main project" from the run menu, I get the error "java.lang.NoSuchMethodError: main
Exception in thread "main"".
Sounds like a path error, can you go to Start > Run > cmd and then type 'path' (without the quotes) into the command prompt and copy what it says here.
C:\Documents and Settings\Ash>path
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\Qu
ickTime Alternative\QTSystem\
You don't have the java bin directory in your path so you will need to add it. In my case it's located at (C:\Program Files\Java\jdk1.6.0_04\bin) but you should browse to "C:\Program Files\Java\" and then look for a folder that has "jdk" in it's name and browse to the bin subdirectory. Once you've found it copy it and type the following into the command prompt, substituting the path to your jdk if different.
path C:\Program Files\Java\jdk1.6.0_04\bin;%PATH%
Make sure you have ;%PATH% on the end or you'll screw up your existing path.
Forgot to mention, type in path again - you should see new stuff in it. Mine is the following:
PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Java\jdk1.6.0_04\bin
I did, but it's the same as before. If I do cd c:\ and then type path, it appears there. Still get the exception though.
You can add it manually via a dialog:
Press Windows Key + Pause/Break
OR
Right-Click My Computer and select Properties
Once you see the 'System Properties' dialog select the 'Advanced' tab. Next click on the 'Environmental Variables' button.
Select the 'Advanced' tab.
In the bottom section of the window that says 'System Variables' select the entry for 'Path' and click on 'Edit'.
Do as before, add a semicolon to the end of the existing information and then put in the path to the java bin. Press 'ok' on all of the dialogs and try running the jar file again, sometimes a system reboot is required.
The path has now been added properly, shows as
"PATH=C:\WINDOWS\system32;C:\WINDOWS;C:\WINDOWS\System32\Wbem;C:\Program Files\QuickTime Alternative\QTSystem\;C:\Program Files\Java\jdk1.6.0_04\bin".
But I still keep getting the error. :(
Can you execute the jar from the command line?
java -jar <jarfile>.jar
Does it give the same exception as netbeans when you try and run it?
All this dicking around with paths :|
Sounds like you're missing your main method (as suggested by the exception, which wouldn't be thrown if there was no java found).
Have you got a public static void main(String[] args) method anywhere? If not you need to add one.
Yes I have and I'm able to run the file fine from within netbeans.
Same exception as netbeans.
This is the main class
Code:
public class GUI extends javax.swing.JFrame {
    public GUI() {
        initComponents();
    private void initComponents() {
        jPanel1 = new javax.swing.JPanel();
        jLabel1 = new javax.swing.JLabel();
        jTextField1 = new javax.swing.JTextField();
        jButton2 = new javax.swing.JButton();
        jLabel5 = new javax.swing.JLabel();
        jTextField5 = new javax.swing.JTextField();
        jLabel6 = new javax.swing.JLabel();
        jTextField6 = new javax.swing.JTextField();
        jButton3 = new javax.swing.JButton();
        jLabel7 = new javax.swing.JLabel();
        jLabel8 = new javax.swing.JLabel();
        jTextField7 = new javax.swing.JTextField();
        jTextField8 = new javax.swing.JTextField();
        jButton4 = new javax.swing.JButton();
        jButton5 = new javax.swing.JButton();
        jLabel9 = new javax.swing.JLabel();
        jTextField9 = new javax.swing.JTextField();
        jPanel2 = new javax.swing.JPanel();
        jLabel2 = new javax.swing.JLabel();
        jLabel3 = new javax.swing.JLabel();
        jLabel4 = new javax.swing.JLabel();
        jTextField2 = new javax.swing.JTextField();
        jTextField3 = new javax.swing.JTextField();
        jTextField4 = new javax.swing.JTextField();
        jButton8 = new javax.swing.JButton();
        jButton9 = new javax.swing.JButton();
        jButton10 = new javax.swing.JButton();
        jButton11 = new javax.swing.JButton();
        jButton12 = new javax.swing.JButton();
        jButton1 = new javax.swing.JButton();
        setDefaultCloseOperation(javax.swing.WindowConstants.EXIT_ON_CLOSE);
        jPanel1.setBorder(javax.swing.BorderFactory.createTitledBorder("Pump Console"));
        jLabel1.setText("Price per litre");
        jButton2.setText("Set Price");
        jButton2.addActionListener(new java.awt.event.ActionListener() {
            public void actionPerformed(java.awt.event.ActionEvent evt) {
                jButton2ActionPerformed(evt);
        jLabel5.setText("Petrol dispensed");
        jLabel6.setText("Amount due");
        jButton3.setText("Reset");
        jButton3.addActionListener(new java.awt.event.ActionListener() {
                jButton3ActionPerformed(evt);
        jLabel7.setText("Total takings");
        jLabel8.setText("Total dispensed");
        jButton4.setText("Reset");
        jButton4.addActionListener(new java.awt.event.ActionListener() {
                jButton4ActionPerformed(evt);
        jButton5.setText("Reset");
        jButton5.addActionListener(new java.awt.event.ActionListener() {
                jButton5ActionPerformed(evt);
        jLabel9.setText("Pump State");
        org.jdesktop.layout.GroupLayout jPanel1Layout = new org.jdesktop.layout.GroupLayout(jPanel1);
        jPanel1.setLayout(jPanel1Layout);
        jPanel1Layout.setHorizontalGroup(
            jPanel1Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
            .add(jPanel1Layout.createSequentialGroup()
                .addContainerGap()
                .add(jPanel1Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
                    .add(jLabel1)
                    .add(jLabel5)
                    .add(jLabel6)
                    .add(jLabel7)
                    .add(jLabel8)
                    .add(jLabel9))
                .addPreferredGap(org.jdesktop.layout.LayoutStyle.RELATED)
                .add(jPanel1Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING, false)
                    .add(jTextField9)
                    .add(jTextField8)
                    .add(jTextField7)
                    .add(jTextField6)
                    .add(jTextField5)
                    .add(jTextField1, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, 83, Short.MAX_VALUE))
                .addPreferredGap(org.jdesktop.layout.LayoutStyle.RELATED, 71, Short.MAX_VALUE)
                .add(jPanel1Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.TRAILING, false)
                    .add(org.jdesktop.layout.GroupLayout.LEADING, jButton3, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .add(org.jdesktop.layout.GroupLayout.LEADING, jButton2, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .add(jButton5, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .add(jButton4, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
                .addContainerGap())
        jPanel1Layout.setVerticalGroup(
                .addContainerGap()
                .add(jPanel1Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.BASELINE)
                    .add(jLabel1)
                    .add(jTextField1, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)
                    .add(jButton2))
                    .add(jLabel5)
                    .add(jTextField5, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)
                    .add(jButton3))
                    .add(jLabel6)
                    .add(jTextField6, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE))
                    .add(jLabel7)
                    .add(jTextField7, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)
                    .add(jButton4))
                        .add(jLabel8)
                        .add(jTextField8, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE))
                    .add(jButton5))
                    .add(jLabel9)
                    .add(jTextField9, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE))
                .addContainerGap(265, Short.MAX_VALUE))
        jPanel2.setBorder(javax.swing.BorderFactory.createTitledBorder("Petrol Pump"));
        jLabel2.setText("Petrol dispensed");
        jLabel3.setText("Price per litre");
        jLabel4.setText("Amount due");
        jButton8.setText("Remove Nozzle");
        jButton8.addActionListener(new java.awt.event.ActionListener() {
                jButton8ActionPerformed(evt);
        jButton9.setText("Replace Nozzle");
        jButton9.addActionListener(new java.awt.event.ActionListener() {
                jButton9ActionPerformed(evt);
        jButton10.setText("Squeeze Nozzle");
        jButton10.addActionListener(new java.awt.event.ActionListener() {
                jButton10ActionPerformed(evt);
        jButton11.setText("UnSqueeze Nozzle");
        jButton11.addActionListener(new java.awt.event.ActionListener() {
                jButton11ActionPerformed(evt);
        jButton12.setText("Reset");
        jButton12.addActionListener(new java.awt.event.ActionListener() {
                jButton12ActionPerformed(evt);
        org.jdesktop.layout.GroupLayout jPanel2Layout = new org.jdesktop.layout.GroupLayout(jPanel2);
        jPanel2.setLayout(jPanel2Layout);
        jPanel2Layout.setHorizontalGroup(
            jPanel2Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
            .add(jPanel2Layout.createSequentialGroup()
                .add(17, 17, 17)
                .add(jPanel2Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING, false)
                    .add(jButton10, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .add(jButton8, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
                .addPreferredGap(org.jdesktop.layout.LayoutStyle.RELATED, 84, Short.MAX_VALUE)
                    .add(jButton11, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .add(jButton9, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
                .add(89, 89, 89))
                .addContainerGap()
                .add(jPanel2Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
                    .add(jLabel2)
                    .add(jLabel3)
                    .add(jLabel4))
                .add(67, 67, 67)
                    .add(jTextField2, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, 88, Short.MAX_VALUE)
                    .add(jTextField3)
                    .add(jTextField4))
                .add(38, 38, 38)
                .add(jButton12)
                .addContainerGap(75, Short.MAX_VALUE))
        jPanel2Layout.setVerticalGroup(
                .addContainerGap()
                .add(jPanel2Layout.createParallelGroup(org.jdesktop.layout.GroupLayout.BASELINE)
                    .add(jLabel2)
                    .add(jTextField2, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)
                    .add(jButton12))
                    .add(jLabel3)
                    .add(jTextField3, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE))
                .add(10, 10, 10)
                    .add(jLabel4, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                    .add(jTextField4, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE))
                .add(66, 66, 66)
                    .add(jButton8)
                    .add(jButton9))
                .add(38, 38, 38)
                    .add(jButton10)
                    .add(jButton11))
                .add(198, 198, 198))
        jButton1.setText("oww");
        jButton1.addActionListener(new java.awt.event.ActionListener() {
                jButton1ActionPerformed(evt);
        org.jdesktop.layout.GroupLayout layout = new org.jdesktop.layout.GroupLayout(getContentPane());
        getContentPane().setLayout(layout);
        layout.setHorizontalGroup(
            layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
            .add(layout.createSequentialGroup()
                .add(layout.createParallelGroup(org.jdesktop.layout.GroupLayout.LEADING)
                        .add(333, 333, 333)
                        .add(jButton1))
                    .add(org.jdesktop.layout.GroupLayout.TRAILING, layout.createSequentialGroup()
                        .addContainerGap()
                        .add(jPanel1, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE)
                        .add(jPanel2, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.PREFERRED_SIZE)))
                .addContainerGap())
        layout.setVerticalGroup(
                .addContainerGap()
                    .add(jPanel2, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, org.jdesktop.layout.GroupLayout.DEFAULT_SIZE, Short.MAX_VALUE))
                .add(jButton1)
                .addContainerGap())
        pack();
    private void jButton12ActionPerformed(java.awt.event.ActionEvent evt) {
jTextField2.setText("0.0");
jTextField4.setText("0.0");
    private void jButton11ActionPerformed(java.awt.event.ActionEvent evt) {
jTextField9.setText("Out of Use");
PumpConsole.squeezenozzle(false);
updatedisplay();
    private void jButton10ActionPerformed(java.awt.event.ActionEvent evt) {
jTextField9.setText("In use");
PumpConsole pc1 = new PumpConsole();
PumpConsole.squeezenozzle(true);
updatedisplay();
    private void jButton9ActionPerformed(java.awt.event.ActionEvent evt) {
PumpConsole.removenozzle(false);
    private void jButton8ActionPerformed(java.awt.event.ActionEvent evt) {
PumpConsole.removenozzle(true);
    private void jButton4ActionPerformed(java.awt.event.ActionEvent evt) {
PumpConsole.balance = 0;
updatedisplay();
    private void jButton5ActionPerformed(java.awt.event.ActionEvent evt) {
PumpConsole.totalpetroldispensed = 0;
updatedisplay();
    private void jButton3ActionPerformed(java.awt.event.ActionEvent evt) {
PumpConsole.petroldispensed = 0;
PumpConsole.amountdue = 0;
jTextField9.setText("Ready");
updatedisplay();
    private void jButton2ActionPerformed(java.awt.event.ActionEvent evt) {
PumpConsole.setpetrolprice(Double.parseDouble(jTextField1.getText()));
updatedisplay();
    private void jButton1ActionPerformed(java.awt.event.ActionEvent evt) {
    updatedisplay();
    public void updatedisplay() {
jTextField1.setText(Double.toString(PumpConsole.priceperlitre));
jTextField2.setText(Double.toString(PumpConsole.petroldispensed));
jTextField3.setText(Double.toString(PumpConsole.priceperlitre));
jTextField4.setText(Double.toString(PumpConsole.amountdue));
jTextField5.setText(Double.toString(PumpConsole.petroldispensed));
jTextField6.setText(Double.toString(PumpConsole.amountdue));
jTextField7.setText(Double.toString(PumpConsole.balance));
jTextField8.setText(Double.toString(PumpConsole.totalpetroldispensed));
    public static void main(String args[]) {
        java.awt.EventQueue.invokeLater(new Runnable() {
            public void run() {
                new GUI().setVisible(true);
    private javax.swing.JButton jButton1;
    private javax.swing.JButton jButton10;
    private javax.swing.JButton jButton11;
    private javax.swing.JButton jButton12;
    private javax.swing.JButton jButton2;
    private javax.swing.JButton jButton3;
    private javax.swing.JButton jButton4;
    private javax.swing.JButton jButton5;
    private javax.swing.JButton jButton8;
    private javax.swing.JButton jButton9;
    private javax.swing.JLabel jLabel1;
    private javax.swing.JLabel jLabel2;
    private javax.swing.JLabel jLabel3;
    private javax.swing.JLabel jLabel4;
    private javax.swing.JLabel jLabel5;
    private javax.swing.JLabel jLabel6;
    private javax.swing.JLabel jLabel7;
    private javax.swing.JLabel jLabel8;
    private javax.swing.JLabel jLabel9;
    private javax.swing.JPanel jPanel1;
    private javax.swing.JPanel jPanel2;
    private javax.swing.JTextField jTextField1;
    private javax.swing.JTextField jTextField2;
    private javax.swing.JTextField jTextField3;
    private javax.swing.JTextField jTextField4;
    private javax.swing.JTextField jTextField5;
    private javax.swing.JTextField jTextField6;
    private javax.swing.JTextField jTextField7;
    private javax.swing.JTextField jTextField8;
    private javax.swing.JTextField jTextField9;
Does netbeans know where this main class is, it's a property of the project which it'll need to populate the manifest correctly when packaging it up into a jar.
When you run it from netbeans are you running the project or running the file?
