Javascript class help.
26 Jun 2003
North West
Im creating a class to carry out certain functionalities.
Here is a snipet of the code where I am having the problem.
Code:
function MyClass()
  this.AddItem = function(id)
     var theItem = document.getElementById(id);
     theItem.onmouseclick = function()
       this.doThis(); // <------ PROBLEM
  this.doThis = function()
    alert("Done it");
the "this.doThis()" needs to call the class function 'doThis' but at the moment it is thinking the 'doThis' method exists in the object 'theItem', but I dont know how to call the function 'doThis' properly.
Can anyone give me a hand?
Thanks a lot.
Hi,
I ran into this problem too, it was due to the meaning of "this" changing. What I did was to set a variable at the start of my JavaScript that pointed to this. e.g
var me = this;
When a function is called this invokes a further function passing in "me" as an argument. That way "me" will always be pointing at what you regard as "this".
I've got some sample code I can dig out if that would help.
Jim
