Hi all,
I've a Jeantech JN120F-600AP12v2 PSU and I woke up this morning and noticed it sounded really rough. Had it apart tonight after work, cleared all the dust out and although it doesn't sound as bad, it's still too loud.
It appears to just be wired directly into the PSU cabling so no easy replacement.
Would just buying a replacement fan, cutting and soldering/taping the wires be acceptable? Any suggestions on replacements or just a cheap one from here?
I believe its a 120mm fan that i need.
