I just had this conversation with Jonsbo. (I'd still like to see your temp data, if you'd share it, and I'm going to attempt the case, regardless; if it sucks, I'll go Meshlicious.)
Hello, In English that isn't broken, please explain what this means: Note : It is recommended to use reverse gpu for vertical installing the high-end gpu. [editor's note: this comment was present on the NewEgg US product page as of 8/12/22] "use reverse GPU": make that make sense, please. What does it mean? (See attachment.)
Dear , Thank you very much for your question. The VR3 is the model with the GPU installed vertically, for good cooling , so we suggest : When the graphics card is installed vertically, it is recommended to use the graphics card with anti gravity function. If there is any other inquires, pls contact us freely. Best Rgds and Thks, Janey Yan/JONSBO
I don't know what a GPU with an "anti-gravity function" is. Could you provide an example?
Dear , At first pls note the GPU without Anti-gravity function also can be installed to our case. On the other hand " the anti-gravity function" is a frontier technology, as we know there is a brand "Igame" , his 30 series gpu has this function. the brand in China is " COLORFUL". May something can help you . Best Rgds And Thks, Janey Yan/JONSBO
What problem exists with this case that would cause someone to require an "anti-gravity GPU"? I have read that certain, if not most GPUs, overheat in the configuration VR3 employs--with the I/O panel facing upward. Is that the problem that you're indicating exists? Please respond without ambiguity.
Dear , Thank you for your reminding, it is our fault not considering the Anti-gravity GPU is not popular now, we make this note just want let the customers to know if can use this kind of GPU will be better for dissipation heat for case with vertical installing the GPU . We will delete this Remark to avoid the miss understanding. Thank you. Best Rgds And Thks, Janey Yan/JONSBO
So, you're saying that current GPUs overheat in the configuration that VR3 requires. (Thanks for clarifying. I'll return it.)
Dear , It is ok, you can return. Best Rgds, Janey Yan/JONSBO
Whether it's your fault or not, you need to clarify "reverse GPU" on the product page so that people understand what you mean by this. To "delete this remark" suggests that you're attempting to cover something up. (That doesn't work, in America.) I'd rather you explain the effect on current GPUs of the configuration required. Do you have data that supports the apparent conclusion that current GPUs don't perform well in the configuration that VR3 requires? I am going to attempt to use my RX 6800 in the case prior to returning it, nonetheless, as I'm curious as to how poorly it might perform.
Dear, As for our model VR3, this is a mesh case, with good dissipation heat by the mesh structure, we have many customers use RX6800 for it, they are satisfied with it too. As for the VR3 case, due to the vertical installing GPU , there are a little affect heat dissipation than the normal level installing, but it is in acceptable heat dissipation range. May there is something can help you. Best Rgds and Thks, Janey Yan/JONSBO
