Hello again guys!
I was just wondering about a few things:
What is the real advantages of 1600MHz RAM over 1333MHz?
Also i heard the latencies are higher on the 1600MHz usually, does this really effect it? If so does that mean 1333MHz is better? (Mainly for gaming)
And an example of a good set of latency for RAM?
And finally, when building a PC, to ground yourself i heard you touch the exposed metal of the case, but i see most cases now are all black painted, so do you still get grounded from touching the case then?
Danke!
Danke!
