My network topology is this.
Upstairs - BT FTTC DSL modem, connected to an EdgeRouter 6P. In this case, into eth0 and authentication is PPOE to PlusNet. My desktop PC is connected via ethernet to eth2 on the EdgeRouter, at the moment via DHCP but will probably allocate a static IP in due course.
eth1 on the EdgeRouter connects to a PowerPlug, that connects to another in the living room. This feeds a cheap switch, which has my XBox and a Ubiquiti AC-LP access point.
eth1 and eth2 on the EdgeRouter are set to allcoate IP addresses dynamically and I can see that wirelesss devices connected to my access point have been allocated leases on my wireless network, via the access point.
Since adding the EdgeRouter, the Unifi controller software doesn't show my access point in the fancy interface. It initially described my access point as 'disabled' - strange as I had devices connecting via it - but after I did a hard reset of the AP with a paper clip and 'forgot' the AP via the Unifi controller, now I can't discover the AP in the Unifi controller software. My AP is sat downstairs, with a white LED showing it is waiting to be adopted. Meanwhile, my wireless devices are all getting IPs from the EdgeRouter.
Is there anyway of getting the EdgeRouter management GUI and the Unifi controller software to play nicely together? I deliberately didn't get a Unifi Security Gateway as I wanted something more robust with a view to adding another access point, a CloudKey gen 2 and some cameras later. Clearly I can't add this lot if the Unifi controller software isn't discovering devices.
Happy to upload pictures of config if it helps
