Permabanned
- 15 Jan 2006
Hey guys. Just build my sister a new PC.. here are the specs..
- Antec NSK 4480 Mini Tower Case (Silver) - 380W Earth Watts PSU
- Intel Core 2 Duo E2200 "LGA775 Conroe" 2.20GHz
- Samsung SH-S203D 20x DVD±RW SATA Dual Layer ReWriter
- Gigabyte GA-73PVM-S2H GeForce 7100 Micro-ATX (Socket 775) PCI-Express DDR2 Motherboard
- Samsung SpinPoint T 500GB SATA-II 16MB Cache
- OCZ 2GB (2x1GB) PC2-6400C4 Dual Channel Platinum Revision 2 XTC Series DDR2
I'm no PC expert by any means, but I have built a PC (mine before), and other than incompatible RAM to begin with, I had no problems.
So the build went well and I booted the PC up and everything seemed to be fine. I put Windows XP in to install and setup began, but during the part where it checks your configuration at the start I got a blue screen (the 'Windows has been shut down to prevent damage to your computer one) and so I reset the PC but now it just hangs on the 'Verifying DMI Pool Data' screen.
Anyone know what could be the problem here? I've tried a few things,
- Checked everything is connected properly and securely
- Tried each stick of RAM on it's own... everytime I changed the RAM around the 'Verifying DMI Pool Data' screen updates to 'Verifying DMI Pool Data ........... update success!' and then it just continues to hang (I've noticed also that in BIOS there is no option for me to change the RAM settings/timings. Very strange.. could this whole thing be a RAM related problem?)
- Resetting to optimized defaults in the BIOS
Alas no luck.
I don't think this is anything to do with the problem but I thought I'd include this info just incase. My hard drive and DVDRW are on IDE channel 2 and the HD is master and the DVDRW is slave (according to the BIOS, but how come if I am connected up via sata?
). Is that okay?
Any help would be greatly appreciated.
UPDATE
I put the hard drive from my computer in to the new build and, sure enough, it booted up in to Windows XP first time. So I now know that, for some reason, I can't get past the DMI Pool Data screen because of the hard drive.
However, another problem seems to have arisen. With the hard drive from my PC plugged in to this new one I can get to the desktop, sure, but after about 3 seconds the computer just resets. No error messages or blue screens, it just resets. Every time. I'm hoping that's just because of the hard drive's settings and drivers all confliction with the new computer's components though.
UPDATE 2
Just put the new hard drive in to my PC and, as I was hoping, I got the ''Verifying DMI Pool Data' error! So, it's the new hard drive then I guess? Not sure why it got past the DMI Pool Data stage the first time I turned it on, but whatever.
Unfortunately I don't have an empty hard drive (or one I can empty) to test in the new computer.
Alas no luck.
). Is that okay?Any help would be greatly appreciated.
UPDATE
UPDATE 2
