Just built new pc, boot device led has light up red. HELP?
okay well it now boots into bios but cant find my optical drive as a boot option, just doubl checked all cables are plugged into it etc...
back to square one. the boot device led has no stoped lighting up but now the vga led is lighting up red and i get no display?+checked all power connections for everything.
okay thanks. Thought id try onboard gpu before i take everything out the case. Will the onboard graphics just take over if i remove my gpu?
Edit* just tried that but still no avail. The GPU led is still red even though there isnt even a gpu in there?
Hmm, no not really:/ Just rebuilt the entire thing to make sure there was nothing behind the mobo and there wasn't. All the fans come on etc but there is no post. The VGA led lights up red which means thats the problem. also i reset bios/cleared cmos to no avail and i also cant seem to get it to run off the onboard gpu.
i would have thought GPU? because it's the gpu led thats on which is showing error? Although i dont know much so im probably wrong :D
Ah right okay thanks mate. Just a quick question, when you RMA it do you have to send it back with literally everything it came with?
