***** JUST IN ***** OcUK Value 2.5" USB 3.0 Aluminium Hard drive enclosure.
20 Jul 2009
The bleak North East arm pit of Britain
Just in today, OcUK Value Aluminium Hard drive enclosure supporting USB 3.0 for ultra speed data transfers and backups when on the move. Perfect for any hard drive you may have left over from an upgrade in the past or from any sata drive purchased new. These value enclosures bring portable storage to a new standard of price value :)
OcUK Value 2.5" Portable USB 3.0 Enclosure (Black) @ £14.99 inc VAT
OcUK Value 2.5" Portable USB 3.0 Enclosure is perfect for the value concious who are looking to get the best value and performance combined. 10x faster than USB 2.0, these drives are no slouch. Built from quality Aluminium and supplied with a leather travel pouch the OcUK Value Portable USB 3.0 Enclosure is ready to go keeping your data safe where ever you take it.
- SATA I/II to USB 3.0
- Backward-compatible with USB 2.0 / USB 1.1
- Maximum transfer rate up to 5 Gbps with USB 3.0
- Maximum transfer rate up to 480 Mbps with USB 2.0
- Hi-Quality shielded USB 3.0 cable ensure data integrity & speed
- Hot swappable and truly Plug-n-Play
- LED indicate Power status & HDD activity
- Portable & compact size for travellers
- OS support: Windows 7 / Vista/XP/2000/ME Mac OS 9.0 or later
- Device Support: Support 2.5''SATA I/II Standard HDD
- Interface Support: SATA I/II to USB 3.0
(USB 3.0 Speeds, the System Must Support USB 3.0 Specifications)
- Data transfer Rate: Up to 5 Gbps
- LED Display: Power LED / Access LED
- Materials: High grade Aluminium, plastic
- Power Supply: 5V Bus Power
- Dimension: 139(L)*83(W)*16(H)mm
- Retail Box: 160(L)*99(W)*42(H)mm
Only £14.99 inc VAT.
ORDER NOW
You do indeed need to provide your own drive however for a penny less that £15 you can turn your unused drives into a speedy external unit thatll happily run close to if not the same as internal speeds. Add to this one of our well priced internal 2.5" drives or even an SSD and you have yourself an outstanding value and exceptionally quick portable drive to take anywhere and everywhere you should wish :)
Andy
Hey,
Cracking value deal here, and like you said the previous problem or downfall with usb2 was its lower than hard drive transfer speed :) Will be purchasing one myself.
Thanks
Oh, sorry. I did breeze through them, but I was busy (in work). :o
Anyway, good. Then I may well consider getting myself one of these. :)
