Killa_ken said:
Well im looking to gain some weight a bulk up so under the advice of a friend i brought some Whey Isolate 80 and 1kg of Maltodextrin.
Could someone tell me what maltodextrin does all i can find is that its a carb!
All the information we have at our fingertips yet we still listen to our mate down the gym..!
What you've bought there is expensive and it's a perfect recipe for getting fat. Why buy Whey Isolate?? that stuff is usefull straight after a workout and maybe even during, that's it. It's absorbed SOO quickly. It will just fly through your body in about an hour and then that's it, all gone and your body is left with no protein source but your muscles until your next meal. This stuff is for advanced body builders ONLY, anyone else using it is wasting their time and money. It also causes an insulin spike (so does whey concentrate but not as bad and it's ten times cheaper)
Maltodextrin? Fine for sipping on while you train and in a post workout drink, fine for taking with Creatine aswell. Sports nutrition companies use this as a cheap filler in their weight gainer formula's... it's not really beneficial to you. Oats are a thousand times better and at around £1 for 2kg they're dirt cheap
This will cause an insulin spike also. So these two mixed together ( 40g whey - 50g maltodextrin ) will make a very good post workout drink. Even better if you mix 5g Creatine monohydrate with it.
I'm not going into too much detail about insulin etc, you can read up about that yourself if you wish. Just know that the only time you really want an insulin spike is straight after training.
You could also mix half that drink and sip on it while you train, this will minimize muscle being broken down for fuel.
If you want to put some bulk on then drink this formula, there's no need for expensive supplements. This is the best!!!
(kcal - protein/carb/fat)
100g Oats ( 390 - 8/70/8 )
40g Whey Concentrate ( 160 - 32/3/3 )
15ml Extra Virgin Olive oil (or some Omega 3-6-9 oil even better) ( 135 - 0/0/15 )
Total = 685kcal - 40g Protein - 75g Carbohydrates - 26g Fat
That's 40g of super high quality protein, 75g of low G.I. high quality, high fibre carbs and 26g of healthy fats. No sugars, sweeteners, additives, fillers, nothing but good stuff and super cheap too
EDIT - For an even bigger boost you can also add milk to this. Aswell as slowing down the digestion, it will also add some essential vitamins and minerals. It will also make it taste better. If you're the kind of person that struggles drinking things like this then you can also add something like Nesquik to flavour it but don't go too mad as it's full of... maltodextrin!!
Oats are your friend, get used to them and eat lots of them, they're food of the gods
they also contain a very powerfull anti-oxidant that's found only in oats.
