You are ok with regards to the cyclopentane, it replaced a lot of the enviromentally damaging CFC-11 and HCFC-141. It might be a very simple fix to repair but the cost will be in the re-gasing of your appliance as I believe that isnt cheap. I would just tell the landlord and pleed ignorance. You will probably not have long becuase the gas that excaped was the the refrigerant and eventually the compressor wont have any gas left to pump around and it will just defrost. If you leave the door shut you might get away with 24 hours or so but i would recommend getting on to the landlord right away. Your fridge might be on a different loop and so potentially could be undamaged but keep an eye on it, it will rise in temp quite quickly if broken, faster than the frezzer for example.
