Just starting out looking at a OC gaming system
8 Aug 2013
Stoke-On-Trent
Hi all,
I was saving up money in a spare bank account to buy a gaming pc but unfortunately lost my job :( so i only have around 400-450 atm for a PC and came across the AMD X4 Raid system.
Trying to keep it as close to the £400 mark as possible Im planning on upgrading the hard drive to - Seagate barracuda 1TB 7200rpm SATA 6Gb/s 64mb cache hard drive.
also the graphics card to - AMD HD 7750 2048mb GDDR3 graphics card.
planning on running everything on Archlinux if it is possible as this will save me a few £ on a OS plus I had a few problems with windows/Microsoft so switched to Linux and i haven't looked back since.
Types of games ill be playing are: BF3 and 4 (when released) Dayz, Gears of war, Dirt, Skyrim
If anyone could help me out abit then it would be appreciated i was considering building my own but as i have no experience in computer building i thought its best to get a already built system.
Thanks
P.s sorry for the bad grammar
Yes if you don't want or feel comfortable enough to build your own system than that AMD FX-4 OCUK system is very nice indeed for someone on a budget.
If you can stretch abit further its worth getting an AMD 7850 graphics card which will be better for future games especially BF4 that you want to get or even a Nvidia 650Ti.
thanks to the pair of you on your input ive looked through a few videos on building your on pc and i think i will be able to do it as ive spoke to a friend who built his own and he said if i need any help he will lwnd a hand so think im going to go down that route now
Two suggestions, the first is over budget though:
YOUR BASKET
1 x **B Grade** MSI HD 7850 OC 1024MB GDDR5 PCI-Express Graphics Cards w/ FARCRY3, Nexuiz & Sleeping Dogs PC Games £119.99
1 x AMD Piledriver FX-6 Six Core 6300 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £89.99
1 x Gigabyte 970A-DS3 AMD 970A (Socket AM3+) DDR3 Motherboard £56.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £51.95
1 x Patriot Intel Extreme Masters 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (PVI38G160C9K) £49.99
1 x OCZ CoreXtreme 500w '80 Plus' Power Supply £34.99
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £14.99
Total : £465.97 (includes shipping : £11.75).
YOUR BASKET
Total : £345.98 (includes shipping : £11.75).
This 2nd option needs a graphics card, so I suggest you find a decent used one, something like a 5850/6870/460/560, should be able to get one in the £50-£60 mark. That's probably what I'd do anyway.
Yeah I definitely would go the AMD CPU route for a low budget system, you will need a minimum of four cores for upcoming games like BF4, Intel better core for core but just too expensive for a low budget system unless you go dual core and I wouldn't buy dual core anymore for a desktop PC.
I think your two specs are very good Potty27, I think it's worth him stretching just a abit more and getting an AMD 7850, a very useful card.
Completely forgot that I was working a week in hand at work so I'm due another payday next Friday so can stretch the budget to 550-600 as i don't want to spend it all on a build as I'm not sure how long i will be out of work for.
think im going to go with the AMD option, But noticed the AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor is currently out of stock so going have to order it from somewhere else :( (wanted to get all my items from overclockers)
thanks a lot potty27
Usually you can order OOS items and they will deliver once it's in stock, could be worth giving them a ring to see when they are expected in. :)
Good luck with your build :)
