Hi,
I've got a K&N cone filter which is due a clean and re-oil. I've bought the official kits for doing it before, and have enough of the spray oil left over to do the filter. I don't have any of the cleaning fluid though.
Rather than order a new kit, does anyone know what the 'cleaning fluid' contains, or whether you could use something like paraffin instead? Would obviously give it a good rinse with soapy water before re-oiling and fitting back to the car.
Cheers
Cheers
). But for the average user... the hassle of buying cleaning fluids and oiling it etc... may as well just use the OEM filter!
