- 25 May 2011
Just wondering if you know of any software and wireless mics that I could setup on my PC?
Thanks
Thanks
Ugh ... Karaoke is Japan's revenge on the world for Hiroshima and Nagasaki.
Wireless mics cost quite a lot mate. You need the receiver as well as mics. My dad does karaoke for a living and his quad wireless mic system cost £375. It’s not something that is as easily done as you may think. You really need a usb interface that can take two mics. This will mix the signal and then you can plug the interface into your speakers/amp. If you are dead set on wireless mics, the receiver outputs can be plugged into the interface inputs. Sunfly karaoke do a system with monthly fee that comes with software and access to thousands of songs in their collection.It's for fun at home
Something that gives some type of score at the end is what I'm after.... Something like singstar but available on the pc for a monthly fee with 10000's songs to choose.
I want wireless mics as well though and both to work at the same time - duets
Anyone clued up on this?
