Well I'll need to throw that stuff away then!!!
Just looking at the image and it looks pretty tight. How hard is it to get them in the holes as I've got some quite girthy ones and don't want to do any damage.
Also when putting it on the bottom, how deep did you screw?
This is ace, thanks! I've roped in my friend to print a few, so will ask for any feedback he has.
Excellent punnage here.Now given the constant punnery, I can read both your first and second paragraphs entirely the wrong way...........
But I've managed to fit lots of girthy ones and they all worked, but easy enough to enlarge the hole if you have a particularly large requirement!
Regarding screwing in the bottom - I'd advise to minimise the distance, I used very short screws there - so probably no more than 8mm needed and it was very secure. Most desks are minimum 18mm so this gives loads of mechanical purchase
I have no idea what you mean.....Excellent punnage here.
Glad to see you have strong views on screwing in the bottom
If you know where to find em, you know where to find em.Has anyone asked for pics yet?
