KDE and Gnome wont load - drivers???
1 Aug 2003
My CentOS box started not loading Gnome properly, it instead brought up an interface that was near unusable (I think it fell back on running twm).
To resolve the problem, I went down to runlevel 3 and tried to reset the window manager to metacity - this failed with the following error message
X server to shutdown FreeFontPath: FPE "refcount unix/:7100 centos" refcount is 2 should be 1; fixing.
I did a quick search and it told me that it was due to fonts not being installed - I installed the fonts and a similar error message came up (this time something about 'built-in').
As far as I have been able to deduce, the problem is with the ATI drivers. The error out putted reads:
Build Date: 05 January 2010
Build ID: xorg-x11-server 1.1.1-48.67.el5_4.1
Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
Module Loader present
Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
(==) Log file: "/var/log/Xorg.0.log", Time: Mon Apr 5 19:04:22 2010
(==) Using config file: "/etc/X11/xorg.conf"
(WW) ATI(0): Failed to set up write-combining range
(0xfd400000,0x200000)
(0xfd000000,0x600000)
The XKEYBOARD keymap compiler (xkbcomp) reports:
> Warning: Multiple symbols for level 1/group 1 on key <I5F>
> Using XF86Sleep, ignoring XF86Standby
> Warning: Symbol map for key <I5F> redefined
> Using last definition for conflicting fields
Errors from xkbcomp are not fatal to the X server
/root/.xinitrc: line 1: gnome-session: command not found
waiting for X server to shut down FreeFontPath: FPE "unix/:7100"
refcount is 2,
Anyone got any ideas?
