From what I have read the pump on the X62 can only be controlled via CAM software. The pump header is for RPM only (I have no idea why is has 2 pins). I assume they don't power the pump via the header as the pump will draw more power than a normal fan and could overload the header on some motherboards.
Does pump speed actual effect temps at all? Higher pump speeds only affect the temp delta between the warmest and coolest parts of the loop and shouldn't make much if any difference at all with a simple 1 block, 1 rad loop like the X62.
