Keeps going in standby
Permabanned
26 Mar 2006
ENGLAND
Since my Belinea 22" is broke, in need of replacement I got a Sony Trinitron Multiscan E250 17" for a replacement till I get my other one back.
It works upto Windows XP logo then when it logs into windows it goes on standby :S
so i tried formatting, it worked till i installed graphic drivers and it did it again
i can only assume windows is putting it into a res it cannot use so monitors going on standby?
need help :/
whatever resolution you set in the display panel will be what it boots up with on the next normal boot. if its still doing it it could be a problem with the card? im not sure what else it could be tbh.
im in safemode now, i set it to 1024,768 and gonna reboot into normal see what it does. :rolleyes:
