- 5 Mar 2014
Hello everybody!
So this is probably very obvious as to what needs to be done but I wanted to ask if any of you have had a similar issue.
So for quite a while I have been having an intermittent issue. Using the pc is perfectly fine for anything until you load a game. Game splash screen loads but once you're loading into the game for example, CS:GO as soon as you go to join a server the pc turns off and restarts. so my question to you guys is that What voltages should my pc be outputting. I had the GPU sent off to be checked under warranty in December and that was sent back to me as fine. So i'm trying to determine if my PSU is faulty and or my MOBO. Any help would be greatly appreciated.
Thanks,
Thanks,
