thefishdude said:u have any other usb devices ?? are they still working ?
alphaomega16 said:You could try unplugging the K/B and Mouse then turn the computer on and once booted into windows plug them back in ???
Oh if you are using a laser or Optical Mouse does the light at the bottom come on ???
Or do the Caps Lock, Number Lock light up when pressed (System must be powered on)
that doesnt mean that the pc sees it as connected thoughSinque said:I placed my phone wire into all the usb ports and when my computer is switched on my phone displays 'USB Cable Connected' so my mobo seems fine...
May have to try repairing windows...
g00dsh0t said:that doesnt mean that the pc sees it as connected though
you need a PS2 keyboard to get into your now defaulted bios and check your usb settings....but very strange not to have any work also
just noticed you have a mx518, they come witha usb>ps2(green)-does that work?
