keyboard problems help!!!
4 Jun 2010
whenever i turn on my computer it runs asus express gate softwere and bios but then beeps once and a message comes up on the screen saying keyboard/interface error press f1 to resume, so i press f1 and alls ok?
the keybord is a logitech g11 and specs of my rig are in sig, it only started doing this today and i just opend it up to do some cable management before hand, could i of unplugged anything?
have you tried plugging it in to another usb port?
what does it do if you boot the pc with no keyboard?
is there any option in your bios that checks a keyboard/mouse is present on startup?
tried second usb- same error
no keyboard- same error with 2 fast beeps then starts without pressing f1
in the bois it looks for a keybord and a mouse and says that they are both there on startup
cant even get into the bios it deactivates the keyboard after leaving express gate and reactivates it after pressing f1 i can tell this by when the lights on the keyboard come on. arrghh
It means that if bios detects an error it will halt the boot sequence, EXCEPT if it is a keyboard error in which case it will carry on.
andy
how do i get to enable that in the bois? i cant find it anywhere :S
just managed to get into the bois using an older keyboard
thanks
