KFA2 770 ltd oc Edition
5 Feb 2012
Hey guys, I own a KFA2 770 ltd oc Edition and was curious if anyone knew some good overclocking settings to try for this card?
Also, Does anyone know if you can control it's light that's on the graphics card?
each and every card behaves differently so the best method is trial and error! as for the light have a search about but I doubt anything like EVGA precision X or MSI afterburner is coded to turn it off/on the only thing I could think of is maybe Geforce experience I saw something about an LED light setting in there.
follow this thread for best results: http://www.overclock.net/t/1265110/the-gtx-670-overclocking-master-guide# (670 guide, applied to the 680, 770=680 so just figuring!) or this one on OCUK : http://forums.overclockers.co.uk/showthread.php?t=18526909
use latest heaven benchmark (4.0) , EVGA precision or MSI afterburner work for this guide, personally I use EVGA precision X.
As for the 770 it is essentially an overclocked 680 but with GPU boost 2 so I don't know what factors that might bring to your overclocking experience but considering the memory on the 770 is overclocked already I wouldn't expect to get much more out of it, Probably some good Mhz to be had on the core though.
The card is sitting at around 3564 memory and 1320 core clock.
Thats with slight overclocked settings on msi afterburner.
