KFC Double Down
Caporegime
9 May 2004
Leafy outskirts of London
I bought a large amount of chicken breasts from Westin Gourmet.
I didn't realise that they would come in 2.5kg packs though.
So I have one of these packs defrosting, and hope to be able to make smaller packs of 2 breasts a piece, but I know that defrosting and refreezing meat isn't recommended.
So most of it is going to get cooked over this long weekend.
Curry one night for sure, but I have also decided to make home-made KFC Double Downs (I've been itching to try once since I heard about them, but the UK sucks).
I've found various 'deconstructed' recipes for KFC seasoning, and am fully aware that without a pressure fryer, it won't be the same, but also looking for member feedback on what seasoning works best if any of you have tried it?
You could just split the packs frozen?
Jam in a knife between breasts and twist, an old knife preferably - it won't do your blade any good.
Nope, it's 2.5kgs of breasts all vacuumed packed a single huge bag, basically a huge chunk of chicken-ice.
That really is a nightmare. I have considered buying that from WG but now it's put me off as I have no need for 2.5kg of chicken to eat at one time after defrosting. Why can't they come in seperate 2 packs or 4 packs even.
I know their sister company musclefood offer the option of having them packed in 2 breast bags iirc, or you could just do what I do when they arrive split them into freezer bags before you freeze them.
Read the OP, krooton says it came in a 2.5kg frozen block. Says it's like an ice block and can't seperate them.
Hmm I must have misunderstood this part
He must have got them fresh and then thrown the pack in the freezer without thinking.
Apologies for my misunderstanding
Correct!
In future, I am considering getting a vacuum sealer so I can make my own 2 breast packs. The savings over supermarket chicken will cover the cost of that pretty quickly.
The chicken is ace quality too!
I did consider that, but long term freezing of non-vacuumed stuff results in annoying ice crystals. :/
When I buy the 2.5kg bags of chicken breasts from WG I open the vaccum packs then individually wrap each breast in tin foil then place them all in a large sealable sandwich bag. Then you dont get freezer burn and can still use them individually.
B
Put chicken in freezer bag. Submerge bag in water which pushes all of the air out (vacuum), twist while still submerged and tie. Much cheaper than a vacuum sealer :p
