Kill coil?
I can hardly tell when the pump is firing up or shutting down!
Shutting down definately can't hear anything, starting up theres a slight wooshing sound of the water going through the rad - but nothing from the pump - I love this pump - tis awesome :)
Hmmm, can you do me a favour. when you turn it off, how long does it take for the pump to stop spinning? I think mine stops quite abruptly and that's what is making the noise.
Curious - you ever run your pump dry? i.e. let the water completely drain out of it?
It'll be later tonight when I get to check mate, will post back then.
Its probably just the remenants of air in your loop. I have heard that rez takes a long time to fully bleed in. Following this closely as I have the same pump + rez for an upcoming build :)
Sorry mate, forgot to post last night!
Checked yesterday - it stops almost immediately once the system has powered down - but makes no noise at all - starting and stopping.
