Killer gaming network card
12 Jun 2007
Ireland
I always thought it a sound card rofl and just found out its a network card yesterday, they say they increase fps and boost your internet or something? is it really worth it or its just waste of pci slot ?
there website: http://www.killernic.com/
a waste. I remember ads for these ont he banners when in the starcraft multiplayer GUI. As if a crazy network card would make a difference in an old school RTS.
BUt even in FPS shooters, I doubt it would make more than a 1ms difference
other than the standard job of taking a few clock cycles away from the cpu this is just an overly priced NIC, and like every other NIC, it runs faster than your netspeed, so, like every other NIC, it is limited by your net speed provided by your ISP, and at a LAN it is limited by the speed of the switches/routers etc
Conclusion, this card is a masively overpriced bog standard NIC with no real world difference from its £10-£20 buddies other than a fancy emblem
I guess the other bonuses are running a Linux powered IPTables firewall on the card as well as a torrent client. VOIP is getting a makeover soon, I guess it has potential... Having IPTables protecting Vista might convince me to get one :P
This man speaks the truth.
They are good for picking your teeth..
And even then, a toothpick would be a little cheaper....
I know someone who has one, he swears by it... i can't tell the difference, and neither can he tbh, as i took the cat5 cable out and put it in his onboard NIC, and he didn't notice for about 5 months...
The PhysX cards of the NIC world....
Virtually nothing for a lot of something*
*Something being your money....
Get one of the numerous linux based home routers out there, i.e. WRT54GS-L or WRT54G-L and flash it with OpenWRT (http://openwrt.org/). Costs a heck of a lot less than this NIC no doubt! Dump it between your modem and your PC, IPTables firewall, problem solved. Cheaply.
Edit: As for the card, what a load of rubbish. Your network latency is affected more by the underlying network topology from you to the server than it is by the processing power of your machine.
I'm surprised Pottsey isn't in here telling us how great it is. He's probably out of a job after physX getting bought out, this would be ideal for him :D
