Kingston 2400 with GA-Z87X-OC, R280X memory issues -Above 1333 = Slower system / No Crossfire??
8 Jan 2009
Hi All
I am looking for some help please.
Just built this.
Gigabyte GA-Z87X-OC - Updated to Bios F7
RM1000 Corsair PSU
Kingston Hyper X 4GBx2 DDR3 2400 - KHX24C11T3K2/8x - IN DDR3_1 and DDR3_2 for Dual channel mode.
I5 4670K (will run fine at 4.5Ghz 1.3v - but running at stock)
Corsair H100i cooler
SSD x 2 (1 boot, 1 data)
Sapphire R9-280X Toxic x 2 Crossfire bridge fitted (In PCIE 1 and 3 - from top)
Windows 7 Ultimate SP1
All latest updates and drivers loaded ok.
1 x 6 pin power fitted to OC_PEG
All boots fine and no OC of CPU, just left at standard 3.4 - 3.8 on Turbo. Intel burn test fine.
X6700 3D11 Marks - OK result.
But memory is running at 1333mhz, so I go into bios and select XMP profile
2 = 2400mhz - PC doesn't like to boot everytime and if does will lock when running 3Dmark, however I can complete Intel burn test OK and CPU-Z shows 1200Mhz
1 =2133mhz - PC boots ok, CPU-Z shows memory = 1066 OK, 3D mark runs but it scores about X3500 and the physics score is higher showing faster ram but FPS is about half and graphics score is 3400 compared to 6600 when ram at 1333mhz.
So it seems with ram above 1333mhz I loose crossfire performance, however 3DMark shows x 2 cards installed and crossfired OK - When looking at GPU activity as 3Dmark is running both cards can show from 50 - 70% activity, never 100%
So its all a bit weird, I have been building systems for 20 years and this is beating me.
From other Z87 experience, I should simply go into bios, select XMP profile and reboot and memory should run at XMP profile speeds and system work OK and performance improved. I should be able to run the 2400 ram and 2400 as its not OC or anything.
Also why am I loosing crossfire speed, PCI-E slot problem, They are both running at PCIE 3.0 8x in GPUZ when benchmarking albeit at 50-70% Activity!?
System runs stable playing Crysis3 etc at 3.8 turbo and 1333mhz, anything above and I have issues.
Faulty ram?
Incorrect placement of 2 x cards in PCI-E slots?
I have tried setting memory manually in bios (Timings as per SPD, Voltage to 1.65) - Also tried changing system agent, CPU IO Analogue and Digital to +0.15/).30 - Still the same.
Its odd, anybody heard of something like this before?
Anytime you take to reply is greatly appreciated.
Rob
Was here when OCUK first started :O)
Hi..
Yep as per manual, its physical slots 1 and 3 from the right of mobo. However they call them DDR3_1 and DDR3_2 !
I have taken out 1 x card so now in non-crossfire mode, I get exactly the same issue when trying to run memory above 1600, FPS gets halved.
As said can sometimes boot at 2400mhz and can run Intel burn etc no probs, just getting massive FPS loss..
So It can either be mobo doesn't like this ram at all or a PCIE problem.
Next test is to remove both PCI-E cards and use on-board and see what happens with that.
Its just weird...
Rob
OK, Did some more testing
Ran with onboard Intel GFX and with 2400mhz ram all is fine and all Benchmarks run fine. So memory/cpu test ok.
Put 1 x R280X back in and again very poor performance, put ram back 1333mhz and it runs smooth as silk.
So I would presume a conflict between high speed memory setting and PCIE operation - So could be bad motherboard or incompatibility with ram.
All a bit weird as runs fine with onboard GFX.
Got me stumped anyway.
Rob
