Hi,
I have a problem with one of the hinges in my kitchen.
The problem is as follows:
The people who installed my kitchen have made an error, the pilot holes they drilled appear to be too large resulting in the screw not getting tight back into the hole.
I had a think about this and filled the holes with wood filler, waited a day and then put the screws back in. It felt strong at the time for one of the screws the other was still not tightening up properly.
I got a feeling there will be more hinges these gits got wrong!
Today the hinge still feels a bit loose I think it will eventually come out like it did this week.
Also this is the end cupboard at the top of the kitchen and there is nothing to the right hand side of it except a window so putting a bit of wood there to screw into will not look very pretty at all.
Any suggestions on what I can do for a more longer term fix?
